Home run panel radiator w/trv
kevin coppinger_4
Member Posts: 2,124
manifold. I have the exact set up in my own home... Buderus 115-21, 22 ser. panels w/ trv, hr to two manifolds. 1 007 drives it. I use a tekmar 260 to control the temp. I used Wirsbo pex and their manifolds w/ shutoffs to connect it up. it works. kpc
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=323&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Home run panel rad with trv
I am planning a circuit with 10 panel radiators. To be piped home run with pap, via manifolds. TRV's on each rad. Do I need to use a manifold with flow balancing. Is there any rule of thumb?
Thanks,
Chris0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
