Boiler run times
greg_30
Member Posts: 8
I have two steam boilers controled by seperate thermostats (24 volt electronic). I'm courious of the run times for each boiler. Any suggestions on monitoring the run times of these two boilers? i.e. hobos, run time meters (w/read outs)
A controls-oriented distributor may have something. Also might check the Cole-Parmer scientific instruments catalog on line.
The thermostats you mention probably don't control the run time of your boiler. They control only when heat can flow to the living spaces (call for heat). There's a separate control for boiler temperature/run time.
