Burner cycle meter
Ron Schroeder
Member Posts: 998
You could just use a simple electromechanical counter with a 115VAC coil like the ones sold by McMaster Carr for about $35.
Ron
Ron
Does anyone know of an affordable meter that will record the number of burner firings? I don't have access to an on/off event recorder, and they're a little too pricy to buy one. I would like to compare burner cycles/run time with and without the Beckett Heatmanager. I already have an hour meter that records down to hundrdths.
Thanks for any help,
Michael0 -
Under a hundred bucks...
http://www.metermall.com/Search/Data Loggers.htm
You'll need a relay with the coil voltage of your choice, and the software to read the device, and a cable to interface the PC with the data logger, but is all R&D and a write off.
I'm sur eyou cpuld cobble someting together out of a Graingers catalog, but what price do you value your labor at?
ME0 -
Just Wondering....
How did you make out? Did the Heatmanager actually reduce burner cycles?
Cosmo Valavanis
Dependable P.H.C. Inc.0 -
I've only had the Heatmanager running since last Saturday (17th). My average without the Heatmanager was around 0.2 gallons per hour, and 3.12 cycles per hour. It would run between 165-190. In the past week with the Heatmanager, it has been 0.17 gallons per hour, and 2.35 cycles per hour. Now it runs between 155-190.
Temperatures have been very similar between the days. However, the .17 gph might be inaccurate because I am getting my gallon readings from my tank guage which is labeled in 10 gallon incraments. With it only been a couple of days and a total of 10 gallons used, there is some error in that number.
The cycles per hour is 100% accurate.
Unfortunately, Thursday morning when I got up, the house was 2* below the thermostats, and the water temp in the baseboard was 90*. I went down to the boiler room and the aquastat was calling, but the Heatmanager was still in Standby Mode (hadn't even switched to Economizing). I turned power off to the system, let the zone valves cool down and close, then powered back up. When the zone valves opened up, everything started working properly again.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
