Tiny in-line Electric Water Heater
Don't think I'd want to use barbed fittings and hose connections in a space heating system...
Am still thinking of options for my [now] under-performing "super-simple" radiant bath floors. Am looking for something that could give a 3°-4°F temp boost @ 1/2 gpm @ with a safe operating temp up to 140° or so.
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    Something like 200-300 watts. Anyone know of such a thing?
    Perhaps some "heat tape" wrapped around copper tube and well insulated?
  • Uni R
    Uni R Member Posts: 663
    Aquarium heaters?
    Mike... Maybe something like this? Italian made and comes in 200 and 300 watt versions.
  • Weezbo
    Weezbo Member Posts: 6,231
    Looks like PLS WIrsbo fittings:)
    that has Got to be a deal:)
  • Ron Schroeder
    Ron Schroeder Member Posts: 995
    That heater looks like the temp is non adjustable since it uses a PTC element.
    Ron
  • Uni R
    The little dial...
    The little dial on the side is the temperature setting. An LED near it shows when it is heating. I think the top temps are probably only about 35C/95F but these are for big aquariums so they are made to do more than 2gpm. Not sure if the temps would be high enough for what Mike wants it to do.
