2\" stainless steel chimney liner?
Ken_8
Member Posts: 1,640
Thanks Paul.
That'll work nicely
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=68&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
That'll work nicely
Know a source?
We have to vent a 50MBTU Munchie into an existing chimney that has two double-45° offsets. Property lines and windows preclude wall venting.
We are pretty sure 3" S.S. liner will NOT make it around the 2 double offsets in this NYC brownstone. We are sure a 2" will (O.A.L.=~30'). Probelm is, no one makes 2" stainless flexible liner.
Any suggestions?
3\" liner
Ken
I was at the HTP factory about 6 months ago.
Someone said that their is a company making a 3" flexible PVC chimney liner. Ask for Chuck or Guy @ HTP.
Rich
Authorized Heat Transfer Products
Service Agent0 -
2\" liner
Ken, I'm pretty sure you can get it. Either through Olympic Chimney or TCE. I can look up the numbers when I get to my shop.0 -
SCH 40 PVC
http://flexpvc.com/
hope this helps...
see ya soon
paul
SCH 40 PVC
http://flexpvc.com/
hope this helps...
see ya soon
paul
SCH 40 PVC
http://flexpvc.com/
hope this helps...
see ya soon
paul
SCH 40 PVC
http://flexpvc.com/
hope this helps...
see ya soon
paul
Flexible metal hose
McMaster-Carr has 2 inch diameter stainless flexible hose. I looked it up in their catalog today. It is .005 inch thick and has a 4 inch radius bend. They call it:
2 inch Semi rigid stainless duct hose, 5515K61
mcmaster.com
Good luck. By the way, there is a version in aluminum.
Metal Liner
Heat Transfer Products will not approve stainless chimney liners for Munchkins. Has to be PVC. Call first before using flexible PVC liners to see if they are approved.
Rich Swatton
Authorized Heat Tranfer Products Sevice Agent0 -
Ken,
> Thanks Paul.
> That'll work nicely
> _A
> 68&Step=30"_To Learn More About This
> "Find A Professional"_/A_
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
