Steam to Water Heat Exchanger
Aidan (UK)
Member Posts: 290
It's not 100%, but for all practical purposes it's near enough. The heat going in with the steam can only exit in the water, in the steam/condensate outlet or as losses from the casing. The only heat lost will be from the outer shell of the heat exchanger. If the condensate is dumped to drain, you'd have to calculate the heat lost with it.
There will be heat lost from the associated pipes and fittings, but that's a different matter. Every heat exchanger calculation I ever did assumed 100% heat transfer. The manufacturers may have detailed figures, but the real percentage is so small as to be negligible.
How do you calculate the energy lost when transfering heat through a steam to water instantaneous shell and tube heat exchanger? It's not 100% because some of the energy is in the exiting condensate.0 -
Aidan's right
The loss is on the order of 970:1, meaning, It takes one BTU to make the water go from 211 to 212°F. It takes ~970 BTU's to make a pound of water change state (from water to steam or the other way around) Simply changing state from steam to water is where all the energy is/goes.
- 87K THE MAIN WALL
- 57 Biomass
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 107 Geothermal
- 70 Pipe Deterioration
- 983 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
