Radiator steam vent
Roman
Member Posts: 1
That steam vent valve that is on the side of the radiator in my closed 1 pipe system. Works fine during heating season but when the heat is off for a while and turned back on , this vent gurgles and has water or condensate bubble out of it until the steam/heat stabilizes. It is oreintated correctly and none of the other valves on other radiators exibit this problem? Bad valve?
Thanks Roman
Thanks Roman
Could be....
...... missing a tongue. A good vent would have a tongue or a siphon tube which helps the trapped condensate drain back into the radiator..0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
