indirect ratings
Rob_35
Rob_35 Member Posts: 33
When looking at indirect performance, such as the TT at
<A href="http://www.triangletube.com/Residential/IndWHPerformance.html">Triangle Tube</A>
what boiler output value should be used, DOE Heating Capacity or I=B=R Net Rating?
Thanks.
  • Al Letellier_9
    Al Letellier_9 Member Posts: 929
    indirect rating
    Weil uses the Triangle tube tanks for their PLus line and the charts they provide use the boiler net rating in sizing the tank capacity and recovery rate. I assume that would be the same for your tank.
  • Jed_2
    Jed_2 Member Posts: 781
    Al
    Are there any ratings or formulas for the Gold Plus when used as a HX for an outdoor wood furnace/P468 series parallel flow, i.e.; mass transfer heat balance with the TT design, to tighten the delta T between the ODWF/P468? Looking for min 175ºF system/185-200ºF ODWF SWT.
    Jed
