High pressure steam
Darin(in Michigan)
Member Posts: 90
Is there a source for correctly distributing steam to a dry cleaner ironing table? The boiler is new but the piping was delicately removed by a hack scrapper with a sawzall. Even if I don't get involved with the project the resource may prove to be valuable. Thanks
Oh, the boiler is a 10 horsepower Lattner boiler(set for 75 psi) and I'm waiting on the specs for the ironing table.
I'd check with Lattner
They sell a gob of these little process steamers and I'll bet their engineering dept has seen them hooked up to just about anything. Pretty sharp bunch anytime I've talked with them.
My brother has a little 3HP and a 7(?) running his smokehouses in the store and they work great. As with any process steamer, water treatment is mandatory if you want to get more than couple years out of it.
What part of the Mitten are you from Darrin?0 -
High Pressure Steam
Good Evening. I'm from the eastern end of the upper peninsula but am working in the northeastern tip of the mitt. My experience with residential steam is pretty good. The only reason I'll humor this tyoe of a project is for the experience. Where I'm at most of the work is residential and light commercial with little room for expanding the knowledge base. I try to get on the wall when I can. I have the deepest respect for the jobs you all do. I kind of want to learn more.
- 120 Geothermal
- 394 Solar
