Pressurtrol Question
superMARKet
Member Posts: 87
"B" controls make contact on pressure rise, and then open again whent he pressure falls. This is usually the opposite of what you want on a boiler where you're using the pressuretrol to control the burner. You want the burner to run when the pressure is low, and break contact when the pressure rises past the setpoint. That's what the "A" controls do.
The "B" is more suited to maintaining a minimum, the "A" is for maintaining a maximum.
What is the differnce between a Honeywell PA404A and a PA404B?0 -
The difference
The "B" is more suited to maintaining a minimum, the "A" is for maintaining a maximum.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
