Munchkin Thermostat Problem
hr
Member Posts: 6,106
it be working fine if some of the thermostats are not working?
You may need someone with a meter and the skill to use it to troubleshoot this.
Could be bad wire, connections, stat with burned anticipator (common with DIY installs:) mis wiring, to mention a few.
This would be hard to troubleshoot via the www.
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
hot rod
My boyfriend just installed a Peerless Munchkin boiler, baseboard heat, it is working fine, house is 74 degrees, however, he has four zones and not all of the thermostats are working. Any suggestions on troubleshooting or fixing this problem. Thanks for any input you may have.0
- 120 Geothermal
- 394 Solar
