Exspansion
Chris_64
Member Posts: 2
I heat with a wood boiler and have 700 gallons of water storage. the temp rise is from room temp 65F to 210F deg. How much expansion should there be. ( 2 tanks 12" X 48") is that enough. The boiler and the storage is under pressure at 12-15 PSI. Any help would do. Is there a site or on this one that has a calculator for this issue.
Chris
Chris
I calculate about 5 ft^3 expansion, or about 30 gallons from 60 to 210 F.0
- 87K THE MAIN WALL
- 57 Biomass
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 990 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
