in-floor radiant heat
Ericjeeper
Member Posts: 179
If you have a digital camera.. Please take a few detailed photos.. Maybe someone can help by seeing a bit of the setup.. Try to show the pumps in their configuration and the zoning. and if you can please try to resize the photos so they will load quickly for those still on dial-up.
I was having a problem with too much heat in one zone of my in-floor radiant heat, seems zone valve was stuck open so I replaced it, (it was a honeywell valve) Now I can't seem to get any heat into zone, I've purged it at leatst two time for a long duration til I cold water coming back out. I am stymied. Can you help?0 -
takes a while usually to come back up....
*~/:)0 -
It's been 36 hours and running. Still no heat. I cannot locate manifold anywhere in house to further check. One heating contractor says it seems like its bypassing, but where?0 -
joe,
try closing all other zones , then purge the radiant.0 -
Hey Guy's,
I have no idea whats going on here.I never posted the message you guy's are nice enough to respond to.Will the real author please stand up.
Joe P.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
