Circulaters in series??
Dwayne
Dwayne Member Posts: 4
Thanks for the info guys.
  • Dwayne
    Curculaters in series???
    Can you use 2 circulaters in series to help flow,or will the second circ. cavitate?
  • Greg_23
    Greg_23 Member Posts: 22
    putting 2 circs in series will double the head,putting them side by side doubles the gpm.
  • Pumps in series
    You can put 2 pumps in series. The effect increases head significantly, while procviding slightly more flow. I've attached an example from our WinCAPS selection software as an example.
    It's important to remember that the preformance of the pumps in series is directly related to the system curve.
