steam boiler limit
doug_31
Member Posts: 1
Is it code worthy in New York to tee off a pig tail to provide operational pressure from boiler to the operational pressure switch as well as the manual reset pressure switch?
ok
Yes, unless there was a code change....But best to have two pig tails. Pig tails plug up .0 -
trap 3/4 \" vs. 1/4 \"
on some larger installations i have recently seen traps fabricated with full 3/4 " b.m. fittings in lieu of a conventional pigtail syphon trap . a little more work but sure won't jam up too quickly.0
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 975 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
