radiant over existing slab insulation ?
Craig Bergman
Member Posts: 84
for insulation on top of the existing slab when using
products like Wirsbo Quick Track or Rehau Raupanel?
I assume that a vapor barrier is required on top of the slab also.
Thanks;
Bergy
Thanks;
Bergy
slab radiant
It depends on how much room you have to raise the floor. Obviously you can put down blueboard and a new subfloor or lightweight pour if you have the room. If not, we've used 1" marine plywood glued and power nailed to the slab, with QuikTrac directly on top of it. There should be a vapor barrier below the slab, so a second one shouldn't be needed.0
- 129 Chimneys & Flues
- 122 Geothermal
