fan in a can
grindog
Member Posts: 121
Can any one recomend a good manufacturer that makes a fan in a can. Doing a basement remodel and need to bring in outside air for combustion
Tjernlund
I have been using the Tjernlund PAI series for my boiler installs using a chimney, and for installing on existing jobs that have tight mech rooms. They are easy to install, can stay up near the ceiling, and have been extremely reliable so far....
Cosmo Valavanis
Dependable PHC Inc0 -
grindog
Fields has the "Fan-in-a Can" combustion air make-up system(you have to supply the connecting pipe).I don't recall the part number, but any supply house should have it available. Tjernlund makes the "In-Forcer" combustion air intake unit. Both interlock with the burner.
Hope this helps.
Jed0 -
Jed
Thanks, I couldn't remember who made the fan in a can! Yeah, either should work fine, I just happen to buy more Tjernlund......
Cosmo Valavanis
Tjernlund
Does make good stuff.0 -
thank you
thanks for the quick replies, your help is greatly appreciated0
