Radiant Slab Paint
Ragu
Ragu Member Posts: 138
Did a 3" radiant pour over an existing slab a year ago, with blanket insulation between layers. Building is presently unused in winter, but heat has been kept on 45 degrees. Building is a dining room/lounge area for 30 adult students. They want to paint the floor with something fairly durable. Building will see winter use this year. I expect winter slab surface temps of 80+. Any ideas? Thanks.
  • Cosmo_3
    Cosmo_3 Member Posts: 845
    Shouldn't be a problem
    As long as it is not painted chrome!!! Just kidding. Even some of the thick epoxy paints are only a 1/16"- 1/8" thick. The darker the color the better, but should not be an issue. Did you run a calc? How much fudge factor do you have? Was the paint the real question?
    Cosmo Valavanis
    Dependable PHC Inc
  • Ragu
    Cosmo
    Haven't got numbers here; supply house did this heat loss. Will get data. Yeah, my question is about the paint being able to stay adhered to a warm concrete floor. Any etching prep involved? Thanks.
  • Carl PE_2
    Carl PE_2 Member Posts: 42
    Don't worry too much
    about the paint sticking. I used "Lucite" epoxy on my shop floor. I didn't mess with the acid wash like it said in the directions since it was new (no oil or anything), just scrubbed it real good w/ soap and water.
    7 years later it still looks great. There's one spot by the door where it's worn through a little bit, and one spot in the back where the paint lifted (can of pvc cement got spilled and sat there all weekend).
    Nothing else will touch the stuff.
  • Alchemy_2
    Alchemy_2 Member Posts: 3
    You might want to look into Concrete stains. Daviscolor, Kemko stain, Scofield, Rare Earth, are some companies that make acid stains. They produce a more natural marbled look.
  • Weezbo
    Weezbo Member Posts: 6,231
    Total Retraction ....We are at the right site and indeed life
    is not dealing me some wild fatastic superimposition...So SOlly guys...i may be little bit Reactive on some levels...i figured i had been hyjacked and wasnt diggin where it was comming from...and thought i would clarify specifically how i felt about the whole deal to what i thought was the person who had manufactured this delight for me ....unfortunately i mistook the first post to come along as having the greatest possibility of my overactive minds meanderings....really i thought this first post was maybe a look a like page dragging me into some deeper entrenchment with the scheme...
  • Alchemy_2
    You lost me there weezbo. Why the hostility?
  • Weezbo
    Major OOPS ...Alchemy...i juxapositioned a difficulty with a
    new search bar i had latch on to me at a gamesite and some minor technicality here with an unfounded idea that they were a part of some nefarious plot bought on by someone who probably hated Bullwinkle and Rocky as a kid.
  • Alchemy_2
    That's a relief. I loved Rocky and Bullwinkle!!!!! I don't post much so it saddened me to see your response. Feel much better now! Good luck with the new Browser. Have you Tried Firefox yet. Great Browser!
    I enjoy your posts weezbo, keep em coming.
    regards
    steve
