Expansion tank brackets
bob young
Member Posts: 2,177
for Kindorf clamps you can also check the refrigeration &a.c. supply houses also electrical supply. double size they come i.d. & o.d. & **** size ! lol
Last week there was a post showing a c-channel bracket that went around a extrol tank - the author was nice enough to give the size and a source. I was not quick enough to save the information.
Anyone know where to get these?
Mupro is one vendor I use
They make a Spiral clamp that works really well around expansion tanks. Here is a picture (Mupro 2) with an Amtrol EX-15 and a 8" clamp.
Hotrod's picture (Mupro 1) is an Amtrol EX-60 with a 10" spiral clamp and the insulator removed.
If your in a pinch, use a "riser clamp" and use all-thread rod to support it out from the wall. Hope this helps.
Regards,
PR
Biggerstaffradiantsolutions.com
strange hook-up
why a gas cock on a extrol tank & a union ??0 -
Future...
It is a simple isolation and disconnect. ½" gas cock is less expensive and has a smaller profile that a ½" IPS ballvalve, and the union is just makes it simple quick disconnect for changeouts. The Wirsbo SSC fitting is for my ½" pex connection to the bottom of my Air-separator.
Regards,
PR
Future...
Regards,
PR
Channel Straps
for x-tanks; 8" IPS for size 15 tanks and 10" IPS for size 30 tanks. They're available at a good plumbing wholesaler.
ah so figured there must be a reason. we actually pay roughly the same for gas cocks & ball valves and like the feel of spinning the tank around so no onions for us. i thought it might be a special type of tank valve . lol0 -
Thanks for the replys
I have the spiral duct hangers from Murpro along with a bunch of other hangers. Will look for the c-channel clamps.
Thanks again
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
