Plumbing Radiator Return
Hi All,
Well, almost there, but since I need to plumb the return within the radiator I'm not sure 100% how to do it. I'm putting rads into my basement and need to run the return within the same rad. I have Slant Fin 30 rads and it's real real tight with the return. I can't use 2 90 degree elbows, but I can do 2 90's and then 2 45 degree elbows..
Question: This there a fitting that I can buy to do my return?
Thanks again,
Paul
  • bob young
    bob young Member Posts: 2,177
    tight center
    use a 90 * el & a 90 * street el and roll the set or a return bend fitting
