Double Wall HX Code Requirement
Tony Conner
Member Posts: 549
Within the last month or two, I read an article, somewhere, that talked about relaxing the requirement for double wall HXs for domestic hot water heating, if the heating medium wasn't toxic. It said the existing double wall requirements stemmed from the "days of solar" (20 or 25 years ago) and folks were using all kinds of potentially nasty (toxic - like ethylene glycol) heat transfer fluids.
I usually print online articles or cut them out of tade mags if they interest me, but I didn't do it with this one. Does anybody have any idea where I might have seen this, or maybe even have a copy they could post?
i remember hearing that also.....
Maybe in some Renai lit ?0 -
dbl hex
plumbing & hvac mag? will check & get back.0 -
dbl hx
Yup - www.plumbingandhvac.ca - the new hydronics, vol. 4, issue 2, by roy collver. also a letter regarding bubble foil issue.Interesting!0 -
It Wasn't...
...in the little pull-out thingy, was it? I can find the main part of the magazine, but not that section.
I really appreciate your help - thanks!0 -
dbl hx
yup - the "pull-out thingy". couldn't find it on the main site. will keep trying. you could try e-mail to:
royc@ms-2000.com - to contact roy collver.0
- 129 Chimneys & Flues
- 122 Geothermal
