General Relativity
Mike T., Swampeast MO
Member Posts: 6,928
The speed of energy can never change from your point of view because what you see is already inside of you.
And you are inside of what you saw.0 -
Reflective and circumspective....*~/:)
Dude
pass that over here ...... mmmmmmmmmm
A question for Mike....
If your trveling at the speed of light, and turn your lights on, does it do any good? Hey Milne, don't be a bogart! Chris0 -
It's okay,
He never inhaled.
Worse yet...
you're going BACKWARDS at the speed of light, and you turn on your headlights... clunk???
Some people never exhaled...
ME0 -
If your going
sideways at the speed of light, it can only be done using flat rate. No beginning. No end. Just circling the universe aimlessly, every few nanoseconds, stumbling upon black holes and string theory, and covering all overhead with quarks.
It's a beautiful thing.
I believe Timothy Leary helped Frank Blau invent flat rate (;-o)
That was exactly the question that Einstein asked
Chris,
With a little math (ok, a whole lot of math), you too could be a physicist.
That was the question that caused special relativity to be born. When there's a paradox, there is a new idea waiting to be born.
jerry
You need to get a real job Mike..........
To much time on your hands or something. Maybe it's the area, a focal point for alien mind rays down there. Hot Rod is always coming up with these wierd gizmo/curvo/contraptions and he lives in that general area too. I'm staying here in Michigan with my feet firmly on the ground and sticking to add , subtract, multiply and a little long division only if mandatory. (G)0 -
Viessmann Research
Mike, This is a special boiler used by Viessmann to research the infrared radiation distribution pattern of a red hot Viessmann boiler. You can see the pattern by the force vectors fastened to the jacket which align themselves with the streams of infrared photons. Kind of says it all. Seeing is believing.0 -
And they say we have the finest up here in the Valley...I'm no longer convinced...- Mr Ed0 -
yeah and turn up that Trower song
and while your at it...gimme that bottle of Jack Daniels. Mad Dog
Mind Tends to Wander
when I'm working on things like this.0 -
Theory
Mike, Is that book in the photo about STRINGER theory? bob0 -
Yep.
"A Treatise on Stairbuilding and Handrailing" by Mowat0 -
J.C.A.
If you're traveling at that speed you ARE the light.
Here's another question:
If you were holding a flashlight and you were the only object in the universe where would the light go?0 -
I ran over that
red porcupine on the way to the cabin in Vermont on New Year's Eve.
That might be a black hole in front. The absence of light being the dead give-a-way.
Then again they say L. Ron Hubbard brushed his hair with it back in '67
Another one of life's imponderable's
If a man says something in the woods, and there's no woman to hear him say it, is he still wrong??0 -
Me, I think about doughnuts and doughnut holes
Relativity? Einstein had it all rigged up with worm holes.
I think if you add them to your wooden stairway, and if you rely on enterprising bugs, you'll see the lights go out.
From the top of the last step, you'll be able to reach another part of the universe in just one big crash, the way flying saucers reach us from outer space...
Give me sufficent duct tape an i could cob anything together
including the crack of Dawn and The Break of day *~/:)0 -
Yup
Its time for the tinfoil hats again.
Locked 'N' Loaded
Tin Foil in hat.check
Ether bottle full.check
Clips full.check
Full pack of cigerettes.check
Sunglasses.check
and...
1.75 liter SoCo ¬
copper clad hollow points ¬
digital camera ¬
pony tail cap ¬
2-quart bottle of Visine ¬
What ?
No tic tac's ??
Someone is feeding those lizards Alcohol ....
This is exactly what happens
when you let the smoke out of an appliance.
They won't work right, afterwards.
Be very, very careful.
If you are cruisin' along at the speed of light, and you drop your flashlight, do you wipe out?
Noel0 -
I have that answer S Ebels
Wife gave me the answer, said yes your wrong because the universe heard you and she felt you were wrong!!0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
