steam two pipe
RoosterBoy
Member Posts: 459
I have a 20 yr old weil mclane 400,000 btu 2 pipe steam boiler..what do I need to do with it during the summer months..it runs fine (although a few of the radiators don't seem to get hot)..thanks
Check the instructions
that came with the boiler. Some makers recommend filling the boiler up to its steam outlets during the summer. If you don't have the instructions, download them from www.weil-mclain.com .
Those cold radiators should be easy to fix. Is this a Vapor system, with traps or water seals on the radiator outlets?
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"All Steamed Up, Inc.
Consulting0 -
don't know where that "roosterboy" stuff came from...anyway..it is a two pipe steam...not sure what you mean by "vapor" but there is a valve at the bottom inlet of each rad and a valve at the bottom outlet on the other side...the rads also have small vents near the top on the side....thanks steamhead so much!0 -
That's a \"two-pipe air-vent system\"
not Vapor. But those cold radiators are still easy to fix. Try the "Find a Professional" page of this site to locate someone near you. If you're in the Baltimore area, contact me.
Consulting0 -
steamhead, I am in the pittsburgh area, but thanks anyway0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
