aquastat
Darren_8
Member Posts: 1
silly-sounding question...
if your aquastat on a residential hot water boiler has 'high' and 'low' settings say, of 180 and 160, what should your differential be set at? What exactly is the diff. for?
Thanx
D
Thanx
D
Is it an 8124? If it is, set the diff anywhere between 10 and 25. At the settings that you posted, I would set the diff at 20, although I set almost all of them at 20.0 -
Diff
It's a adjustment of the range for the low limit.
Depends on the system or needs as to what to set it on.
Factory 5* drop + diff equals low's top setting....
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 939 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
