Weez
S Ebels
Member Posts: 2,322
Chuck Shaw says he's doing a Munchkin class up in Alaska. He has it posted on the Community Bulletin Board below. Didn't know if you had seen it or not.
That is very cool *~/:) ...
as i am nearly crosseyed from taking plastic checks out in a bout as cramped a space as a guy could want ....:)where one looks out the corner of his eye with his head thouroughly denting the sheet rock an what is left of my brain cell ...:)and feels like one of those jim carry boogie eyed cartoon guys...
sheesh i woulda never seen it ...:) luckily there arent alot of drivers at this time of day
may take me a week to see straight again
)) this ought to be a part of the master plumbers exam
)) ok ust the union loose spin the pipe outta the way spinn off the adaptor nipple and other half of the union...now dive down under the return header turn 90,...Breath e IN ...:) skinny past the backflow preventor down pipe,now stick your head into the space that is now available ...push your forehead Into the sheet rock...now spin your eye by 90an inch away from your eye is the fitting ...see in there? man what a bugger! :)re wrapping myself outta there was the best part
...sorry...i aint snivelin... i am just strugglin
Weez
Is it possible that the extreme temps have frozen certain areas of the brain?
Can't tell you how much I look forward to seeing your posts and then trying to understand them. Don't you ever die.
Tom Atchley
thats why we wear snow caps in ALaska *~/:).. helps keep the
Brain from feezin up :)one good thing is , one tends to think a heckalot faster in the - 40's and colder
usually i can see other peoples thoughts ..Its That Good!
- 129 Chimneys & Flues
- 122 Geothermal
