distance between monoflow tees
ted m
Member Posts: 1
is there a maximum length of 3/4 baseboard radiation that can be installed between the supply and return monoflow tees of a one pipe hot water heating system . supply trunk 11/4, with 11/4 x 3/4 monoflow tees
Delta Tee
The distance of the tees should be the same as the radiation for maximum flow....0
- 129 Chimneys & Flues
- 122 Geothermal
