co detector
shawn_5
Member Posts: 52
I would like to know where i can purchase a co detector so I can start using them in my area on jobs nobody around here uses them and how much do they go for.
Shawn, I hope you don't mind the shameless plug here but it does answer your question. I have what I believe to be the best CO Detector on the market today made by Coexperts I know many here will agree. You do have purchase them by the case however.
Low Level Carbon Monoxide Monitor to keep your customer safe.only $89.00 Each, These must be purchased by the case.There are 12 to a case
Please consider checking them out at the store on www.oiltechtalk.com
Your friend in the industry,
Alan R. Mercurio
www.oiltechtalk.comThere was an error rendering this rich post.
CO Detector or Analyzer
I believe you are asking for an analyzer. To do the job right a meter that reads O2, CO & Temperature is the best way to go. These analyzers can cost from $500 to $$900 depending on what features you would like. Any time someone wants to buy a tester I want to see them maximize its ability. Usually this requires some training or at least more information than can be written here. If you would like more information you can call 800-633-7058 and I can give you info on Bacharach, Testo, TSI, UEI, Fluke etc. Do not buy something that you find out later is inadequate.0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
