Can I control a veissman atola system via crestron?
joel_19
Member Posts: 933
The question shouldn't be can you controll it that way . The real question is why would you want to??
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=254&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Crestron control of Veissman Atola system
Is there a way to control the floor heating via a crestron system.0 -
You might want to ask that question at the crestron group on Yahoo. It seems to be a very active group.
Just curious - what do you want to control from a crestron system? I'm not familar with crestron, but am familar with HAI and Elk automation systems. I was planning on a simple interface between my own HAI system and my Vitodens using the contacts for day/night setback and the alarm contacts. This kind of interface is very simple for virtually any automation system.0 -
Crestron
Depending on the control you have? If it is a Comfortrol you can do daytime or nightime changeover (occupied or unoccupied mode) but as far as changing the curve or slope of your radiant floor mixing valve, no.0
- 114 Geothermal
