Plumbing help
Weezbo
Member Posts: 6,231
the one handel metal one is like ok turn it off then after you finish washing the clothes...the other one well it figures that you are away from home for a weekend vacation and the minute you step out the door the hose breaks the gizmo in the box goes woopie! i get to do something right and turns the water off. there is a gizmo called a wogg or wagg looks like a small brass submarine once it figures out its going down to davey jones locker it turns off the pipe or solenoid of your choise...i cant find the lit on the little gold submarine :( it is something like a sump switch...just looks real cool :)
I need
an alternative to this:
http://www.watts-intelliflow.com/default.htm
The body is plastic and the 5th Ave building won't allow it.
Thanks to all who can help.
Guy Gray
makes metal washer boxes, but I don't know if the have an "Intelli-Flow" device. You might want to give them a call.
http://www.ipscorp.com/gg_html/singlelever.html
wags
waggs unit is also made by watts. if bldg. will not approve one w/ plastic components ,tenant will have to do with manual shut offs. ya can't have it both ways. maybe watts can special order a all metal unit. if they live on fifth ave they gotta have cash .if you must know the price you can't afford it.0 -
its not building
Its not that the building probobly will not allow it, but its NYC code that does not allow pvc or plastic. Guess people are just getting lazier and richer0 -
plastic
the n.y.c. plumbing prohibits plastic pipe for multi-storey and commercial applications for very valid reasons. and laziness has absolutly nothing to do with it. plastic has its uses but for the most part it is dangerous and garbage. a n.y.c. lic. plumber . if the people got the cash and desire an all metal unit could be fabricated. if not too bad. let them go to a laundramat.0 -
Not Inexpensive But
Tile pan with curbs, liner, cement board or mud base and a floor drain. Surely NYC allows the good rubber liners as opposed to lead or copper. Used that construction in my attic and was VERY glad when renter left and washer overflowed. It saved my 2nd floor ceiling and floors.0 -
Floodstop
Take a look at this, it may be what you need.------------------------------------------------------------------------------
FloodStop I for Washing Machines
Washing Machines can leak and hoses can fail or rupture at any time.
Avoid extensive property damage and expensive repairs.
Features
Washing Machines are one of the most damaging appliances within the home. Washing Machine related flooding can happen at anytime, from hoses with ruptures or cracked fittings, to internal failures from clamps, valves, pumps, drains and failed switches. Whether at home, at work, or on vacation these flooding
events can go undetected for hours or even days. FloodStop I automatically shuts off the water supply to the Washing Machine and sounds an alarm, leaving all other household fixtures and appliances operational. Easily installed in ten minutes. Each
kit includes two ¾ inch solenoid valves (hose threaded with union), a simple control unit, a water/leak sensor and an AC power adapter.
Prevent Flooding from Failed Washing Machines
& Hoses!
model Floodstop I
- 87K THE MAIN WALL
- 57 Biomass
- 111 Chimneys & Flues
- 5.7K Gas Heating
- 106 Geothermal
- 70 Pipe Deterioration
- 978 Plumbing
- 6.3K Radiant Heating
- 387 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
