Need help with Repco model LA100C
Duane
Duane Member Posts: 17
What appears to be the air bleeder valve on top of my Repco boiler is covered in crud and leaking water. It is the can-shaped object sticking right out of the top of the unit.
I cannot find manuals on-line, and need to know how this is attached. Right now it swivels around which is alrming. Is it just a pipe thread connection ? Is this a Home Depot item or a special part ?
Saw some bad comments about Repco units on the web. Is this 1981 unit garbage ?
