Cerculator makeing noise
RoosterBoy
Member Posts: 459
hi guys I went down stairs this morning and the baseboard zone sounded like a water falls like water was running
I felt the pipe and they where hot do you think this is a air problem in the line or a bad circulator going bad from dirt
the whole system is a few months old buderus g115-28 with lt 160 and 2107 out door reset
I have a air scoop on it now but I am going to replace the air scoop with a sprirovent soon
thanks
thanks
probobly air
well most likely sounds like air, make sure the air vent is open on the scoop, try purging it and see what happens before you install the spirovent. Also what type of circ is it, is it a sealed cartridge type? seen the larger in line like the b&g with couplings make noise but not a bad loud noise. Basically its a new system and the air in the water is coming out and pocketing, bleed it and see0 -
yea thats the frist thing i did this morning was bleed the air it seems better now but i wonder how the air keeps geting in
i am useing taco 007 with ifc0 -
Hows your pressure?
> i am useing taco
> 007 with ifc
Hows'....
Your pressure? Is your expansion tank ok?0 -
pressure seems fine I guess because the p.r.v is not popping so it's under 30psi and the hydro zone is fine
thanks0
