Steam pipe insulation
Glen_5
Member Posts: 21
I have a one-pipe steam system with its original asbestos insulation. I will deal with that in time, however there are several areas where the old insulation has been removed and bare pipe remains. I would like to insulate those sections to prevent early condensation and would like to know the best way to do this. I have seen fiberglass sleeves, fiberglass rolls, mineral wool, etc as possible options. Any feedback appreciated. Thank you.
my opinion
The easiest and quickest while not sacrificing quality or paying far too much, in my opinion, are pre-formed rigid fiberglass. There are some other materials, but I've had a hard time finding them, whereas you can get the pre-formed reigid fiberglass at any plumbing supply store. You can't use most foam products which aren't safe at steam temperatures.
They also sell it at Home Depot/Lowes, but it's extra-thin there and not very useful. You'll probably want it at least an inch thick.
-Michael
You should get the fiberglass insulation. Don't go to Home Depot or Lowes. Go to a heating supply store. It comes in 3 foot lengths. If you don't know the diameter, put a string around the outside of the pipe and bring it to the heating supply store. Try to get at least 1 inch thick. A lot of the smaller diameter pipe insulation comes in 1/2 wall thickness. You may want to insulate over that.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
