Bomb In Basement
Chris V
Chris V Member Posts: 36
Just thinking Out loud...Other Than Cost...Would'nt It Be A Good Idea To Have 2 Openings In A Water Heater For 2 Relief Valves in case one does'nt open?
  • Chris V
    Water Heaters
  • Chris V
    Water Heaters
  • Chris V
    Water Heaters
  • Chris V
    Water Heaters
  • Chris V
    Water Heaters
  • Maine doug_10
    Maine doug_10 Member Posts: 7
    Be careful
    the Department of Redundency Department will get you.
  • jim lockard
    jim lockard Member Posts: 1,059
    If you
    install as many T&P reliefs as you do posts you should be ok. Best Wishes J.Lockard
  • Aidan (UK)
    Aidan (UK) Member Posts: 290
    Bomb in Basement
    The UK practice is to have a pressure relief valve on the cold feed and a T&P relief valve screwed into the water heater body.
    If you'd like to read about the effects of a water heater bursting, you might be interested in the report at:
    http://www.maib.dft.gov.uk/sites/maib/cms_resources/dft_masafety_504222.pdf
    This is a report of an enquiry into the sinking of a 54' fishing vessel, which sank about 10 or 12 minutes after the on-board water heater exploded.
    "The water cylinder (heater) body would form a missile as a result of the explosion. The missile velocities calculated were such that the missile would have been expected to breach the hull in both cases."
    The water heater exploded because of the use of inappropriate plumbing components, possibly to cut costs. The crew survived only because of their safety precautions, i.e., radio batteries stored at high level & life-jackets stored on deck.
  • Constantin
    Constantin Member Posts: 3,796
    Another reason to sail catamarans...
    ... more redundancy, more air chambers, no keel to suck you down to King Neptune.
    But seriously, how is one to fit multiple T&P valves into a water heater in such a way that the T&P valve sees the critical temperatures that are meant to set it off? That thermostat has to stick way into the water heater or it'll only release on pressure, not the super-hot temperatures that can occur if you do a stacking test (either in a lab or through normal usage in the home).
    We have a water heater in our boat. It has a OEM T&P... and it'll soon have a TRV on the output because the current water temps that thing is producing are melting the components in our hot water system.
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,010
    In small print...
    ... on the box the T&P comes in it says to test the valve yearly. I've found lots of plugged T&Ps. Fortunately, modern thermostats work pretty well, or water heaters would be in the news more. By the way, it is the action of the anode, attempting to protect "noble" metals that can plug a T&P. A second T&P would get plugged the same way. Testing is just possibly a better fix. ;~)
    Yours, Larry
  • John Mills_5
    John Mills_5 Member Posts: 952
    Too much thinkin'
    We have a customer that had his generic gas WH blow on him a few years back. He was in the living room, it was in a closet off the LR. Blew a big mirror off the wall across the room, barely missing him. 2nd relief could have helped.
    Test them? Usually that just leads to dripping from my experience.
  • Boiler Guy
    Boiler Guy Member Posts: 585
    Watts has a good training video on water heaters
    that shows the effects of faulty controls and exploding units
  • EJW
    EJW Member Posts: 321
    Relief valves
    a 2nd wouldnt have helped but him but piping it down to the floor would have. EJW
