Burnham Revolution
Saggs_2
Saggs_2 Member Posts: 3
Anyone have any experience with the Burnham Revolution gas boiler? Looking for a reliable DV castiron gas boiler, any input would be appreciated. Thx
  • Robert O'Connor_3
    Robert O'Connor_3 Member Posts: 272
    It is a great boiler. There are some applications that it is better suited for than others. Tell us more about what you will be using it for.
  • John R Leny
    John R Leny Member Posts: 14
    Revoloution
    Tommy,
    Is the Boiler suitable for an under the stairs replacement and is it quiet?
    John
  • loose cannon
    loose cannon Member Posts: 15
    The Revolution is pretty much silent when running. Especially if it is a direct vent application. It has a really nice internal bypass that protects if from cold return water temps too.
  • ScottMP
    ScottMP Member Posts: 5,882
    very few
    heating applainces are allowed under the stairs. In the case of a fire you are burning your only means of escape.
    Scott
  • ryan_7
    ryan_7 Member Posts: 50
    revolution
    You would not believe how quiet they are. I love this boiler. 87 percent efficient and cast iron, what more can you ask for
  • Well Ryan
    You could ask for the Revolution II boiler in addition to the Revolution. This one is condensing at 90%+ without the need for proprietory controls such as modulating valves and the such. Take a look. Thanks for the kind words of support by the way!
    http://www.burnham.com/residential/revolutionII.cfm
    Glenn Stanton
    Manager of Training
    Burnham Hydronics
    www.burnham.com
  • Glenn speaking of that
    when would be a good time to get on HVACTV about the new Revolution II?
  • Shortly Tim
    I spoke to Bill about that and he should be getting in touch with you shortly.
    Glenn Stanton
    Manager of Training
    Burnham Hydronics
    www.burnham.com
  • jim lockard
    jim lockard Member Posts: 1,059
    With a variable
    speed circulator, that as the water comes up to temp the pump speed incresces. J.Lockard
  • Saggs_2
    Thanks to everyone for the response on the revolution! I'm very happy to hear it is so quiet. The customer has had it with his fields external power venter which is under his bedroom and driving his wife nuts. I plan on putting a Smart 30 or 40 on for DHW production, he only has one zone in a small ranch house.
