boiler wiring
shawn_5
Member Posts: 52
I am installing a tekmar 3 zone injection piping system of a existing boiler for radiant and I am installing a boiler protection loop on it. NOw my question is where do you wire your boiler protection pump into.
not enough info...
just call 250-545-7749 with more information.
If you are refering to the Variable Speed Injection Pump, it should connect to the tekmar.
Mike0 -
Why not
wire it parallel with your system pump where it turns on whenever there's a call for heat?
BTW, does the tekmar controller you have include boiler protection? You may just need to add another sensor.
I am using the tekmar 356 an no its not the injection pump it is the boiler protection loop pump0 -
Call
Mike, the Mechanical Magician at tekmar (see phone number above).
Tekmar
The Tekmar 356 has boiler protection built into it so you do not need a bypass to protect the boiler from low return water temps, unless you are talking about the main loop pump in which case I usually wire a relay that turns on the pump when the 356 gets a call for heat.
S Davis
Apex Radiant Heating0 -
couldn't have said it ...
...any better. Thanks Scott.
Guys, you're gonna love tN4!!0 -
I cant wait for the tn40 -
Available this Summer and coming to a location near you...
...check the list of Location and Events .
Mike0 -
April 7th
in Oakland..........will that be you coming this time, Mike?
I wish, but no...
it will be Jason Nelson. He's an excellent instructor with a knowledge base that I feed off...You'll have an amazing day.
If I was coming back to town, Alan, you'd be one of the first to know. Am still having dreams and flashbacks of the wonderful dinner we had together with Chuck Shaw.
It is definitely a 'must do again' event!!
Mike0
