Copper wet return
Brian_31
Brian_31 Member Posts: 9
I read on another thread about determining a clogged wet return if the water level in the boiler drops a considerable amount and takes a while to recover after the heat cycle. The wet return was replaced with copper which travels under the floor to the boiler about 10 years ago.
A new boiler was installed two years ago and the most of the "mud" was cleaned out of the return. Can sediment build up in the wet return? Is there a good method to clean the wet return?
  • jim lockard
    jim lockard Member Posts: 1,059
    Returns
    If you lok to the upper left side under Steam Problems. Dan has a section on cleaning wet returns. Best Wishes J.Lockard
  • jim lockard
    Returns
