steel
thrownet
thrownet Member Posts: 1
Does anybody know the carrying capacity of steel trusses.Or have any web sites containing this info. I have to hang a heavy waste oil burner 850#.
  • Bill_14
    Bill_14 Member Posts: 345
    Need more information.
    nm
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    Metal trusses--particularly those supporting roofs--are often tightly engineered to the expected load. Be vewy, vewy, careful. It's going to depend on the construction of the truss, the design load, the position of the new load and how much you can spread that load among the trusses. Probably best to consult a qualified engineer.
    Remember the recent heavy rains in Southern California? Flat roofs (I bet steel truss roofs) were collapsing under the weight of rain. I presume it was raining faster than it could be drained from the roof and they had VERY little additional load factor. After all--no snow and it never rains in Southern California...
  • Michal
    Michal Member Posts: 213
    CONSULT STRUCTURAL ENGINEER
    I will tell you right now, might not work. You will have to span many trusses, and even then definately would suggest getting a Structural Engineer in there to look at it, they are not great with point loads, load has to be tranferred over a great area.
  • John Shea
    John Shea Member Posts: 247
    What about...
    I-beam. Talk to a local supplier of structural building materials. They may be able to help you along the right path.
  • ALH_3
    ALH_3 Member Posts: 151
    Engineer
    I also vote for consulting the engineer. Loads are frequently deflection based and based on numerous factors the 850lb could and probably will cause unacceptable deflection even if the truss does not fail.
    -Andrew
