This is a closet boiler
for combution air???? Some of theses should have air boots on them.....kpc
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=323&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • FRANK_24
    FRANK_24 Member Posts: 80
    Unlike the other pics of a closet job, that was a ballroom compaired to this. They kept adding on, and on, and on. Everything works, all zones get hot, and no complaints. Just had to show you guys what some people will do. [But we all know what can be done.] Best part about this...........it's my shop/office boiler!!! If you look closely, you'll see there is another door cut in on the left side.
  • clammy
    clammy Member Posts: 3,242
    weil 68 or 66
    Wow old boiler a little tight what's the chances of removing the top and getting a brush down through the pins it looks like removing the top or pulling the flue off would be real fun at 12;30 at nite some times i am so glad to not do 24 /7 oil service any more .But i dig the rellio on there what kind of number she giving and if i remenber correctly alot of those cann through with low speed burners peace and good luck clammy
    R.A. Calmbacher L.L.C. HVAC
    NJ Master HVAC Lic.
    Mahwah, NJ
  • David Sutton_6
    David Sutton_6 Member Posts: 1,079
    Just gotta love them closets!!
    not enuff room to change your mind in some of these ;-)
    Good luck on that one...David
  • That's alot of pipes
    crammed in a small spot , but c'mon Frankie ..... 2 doorways to access the boiler ? That's 1 1/2 more than what we usually work through . Next time I replace a boiler I have to pipe on my hands and knees , under a set of stairs , I'll remember the ballroom comment . You almost sound like my manager and salesmen :)
    Actually , I never seen so many pipes connected to a boiler in such a cramped spot . The most we had was 4 zones and an aquabooster under the stairs .
  • frank_25
    frank_25 Member Posts: 202
    Two doors
    This boiler is actually installed in a closet at my shop. Over the years, there have been three major renovations involving acquired space until now we occupy all of it. [about 5,000 sq.ft.] There are about 7 or 8 zones mostly bb, w/ two injection radiant zones. The boiler is a wm 366 burning .85gpm. We naturally service the unit and keep up w/maintenance being an oil co. The side door was added during the expansion of '02. Now it's EASY to remove the top jacket and brush. AS you guys notice it, the origional job was not piped as pumping away and we just kept adding to it. There are five mens/ladies rooms as the DHW load. WE had one complaint last year about a single office being cold, so we split the run and added a zone valve [simple]
  • frank_25
    combustion air
    you can't see it, but there is a 12 x 12 ducted fresh air to outside, and we always re register the boiler w/ NYC and do an annual boiler inspection. That bit of rust is not indicitive of the rest of the boiler. It's still in good shape. [I wouldn't want to replace it though.] Uggh!
  • frank_25
    omg!
    > these ;-) Good luck on that one...David
    > _A
    > 386&Step=30"_To Learn More About This
    > "Find A Professional"_/A_
  • frank_25
    omg!
    Well, I still beat your install..I have TWO doors and you have only one. lol Did you wipe the K-Y off the door jams when finished? Must leave the h.o. satisfied and no dirt or smudges.
  • David Sutton_6
    K Y...mmmmm
    Now that would have been a great idea , we used spit and a running start LOL
