Radiant Floors
to test the Gyp-Crete for moisture content and you only want to install the hardwood once it's dry.
Hardwood over radiant links:
http://www.warmboard.com/
http://www.hardwoodcouncil.com/tips/tip5.htm
http://www.woodfloorsonline.com/techtalk/woodwater7.html
http://www.heatinghelp.com/newsletter.cfm?Id=19
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=53&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Radiant Floors
    I am a heating contractor installing a radiant floor system. My finished floor will be wood. We poured gyp-crete with 1 1/2" nailing strips two months ago. The a/c's have been running the entire two months. Is it safe to start installing my wood floors without firing up the boilers? Any input appreciated ASAP.
  • SVDW
    SVDW Member Posts: 80
    A lot of our guys tape a sheet of clear plastic on the floor, sealing around the edges w/tape. Moniter for a couple of days & look for moisture under the plastic. If no moisture appears you're probably golden.
