Mike T., Swampeast
Mike T., Swampeast MO
Member Posts: 6,928
BB in series loops?
One zone? Multiple zones?
New system or existing?
Will try but my best but you must realize that my best understanding is for truly proportional systems that maximize comfort, efficiency and economy (even if I do recommend the most expensive & inherently well-controlled boilers). In my mind, anything less is an unnecessary compromise.
hi mike I'm hoping you can help me i have a buderus with a 2107 outdoor reset with baseboard heat.
should i get the buderus BFU room sensor i am running a
t-stat and my PUMPS are hooked to a taco zone controller
thanks0 -
one zone 2 loops new baseboards just took out my hydro air and using the air handler for A/C only
take a look at my other post subject: Buderus Help
thanks mike0 -
Will do but reply won't be immediate. Must study.0 -
no problem mike take your time i really appreciate your input
thank you0 -
Can you e-mail me a sketch of the current system layout?0 -
email sent
thanks mike0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 951 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
