Tekmar 270 & Peerless Pinnacle
hydronicsmike
Member Posts: 855
...please call me during the day at tekmar at 250-545-7749, Ext. 214 and we'll talk about this.
Looking forward to hearing from you.
Mike
Mike
As I understand, the Pinnacle can use a 0-5VDC input to modulate the boiler. The Tekmar provides 0-10VDC. In reading the Tekmar manual, it allows to set Max Modulation signal as a %. Does anybody know if I would compromise anything by setting the Max Modulation at 50%? This would equate to 5VDC, but I wonder if I would give up 1/2 of the range the controller is capable of, and not give the boiler a nice smooth reset curve. The other option is to put a resistor in series.0 -
Brian - 2nd message
can you please call me again?? (Should have grabbed your number earlier).
I've got some updates for you. Don't cut the jumper just yet.
Thanks,
Mike0 -
bump
Mike, Please keep your notes for me.......
I had to go out of town for a few days, back in the office early next week, I'll call you then....THANKS !! Brian0 -
No problem Brian, but...
...I am leaving next Wednesday morning myself. If you miss me, plase talk to Jason Nelson at our office.
Have a save trip!!
Mike0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
