monoflo tee system
pitman9
Member Posts: 74
will never exceed the PEX rating, yes.
Can I use pex tubing to connect two iron monoflo tees that have
had the cast iron baseboards removed and been capped off?0 -
Yes
.0 -
I have seen ratings of 180 degrees at 100 psi
how do I know what psi is going through the monoflo?0 -
it'll be fine
that's how we do it all the time0 -
for underfloor? too hot!
If this is going under a floor, you don't want it too hot. If you add a circulator pump and a mixing valve in the loop, you can bring the temp down. See here.
http://www.pmmag.com/CDA/ArticleInformation/features/BNP__Features__Item/0,2379,62497,00.html0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 951 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
