Glenn Stanton
Glenn,
I have a question on clearance for Z-vent installed on a Burnham Boiler. The Boiler (Spirit) installation manual allows several different venting manufactures (of which Z-vent is one) and states:
Vent pipe minimum clearance to combustible
material is five (5) inches when vent is installed in a
fully enclosed (chase) application or four (4) inches
when vent is installed with at least one side open,
similar to a joist bay application.
The installation manual for Z-vent states:
System Operating Temperature 480F (249C)
Clearance Enclosed
Horizontal 8"
Vertical 4"
Clearance Unenclosed
Horizontal 1"
Vertical 1"
Does the Boiler Installation Manual take precedence over the Z-vent Installation Manual or vice versa?
Just looking for your opinion on this before I go to the AHJ.
Thanks,
Pat Clark, Bell Plumbing & Heating
  • Pat
    The boiler installation manual takes precedence and as always, your local and state code overrules that!
    Glenn Stanton
    Manager of Training
    Burnham Hydronics
    U.S. Boiler Co., Inc.
  • Thanks Glenn
    Will check with them to make sure. It is less than the 6" from the older manual so that helps.
