Before After conversion-PGP
Thanks, HB; I've installed several dozen of the GS1 model. As you know, it replaced the RN series. The burners have been re-designed without the carbon rods, which were somewhat of a problem. The Vitoronic 200 is a very stable platform. I tend to use this model on gravity CI replacements or high temp applications. A full port bypass must be installed on the boiler outlet, is system water content is over 3x boiler content, or if system temp is not over 130 within 5 min of boiler startup. I always use the boiler stand to make the machine easier to work on.
I really like this boiler, the Vitodens is not best for ALL applications.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=104&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
