Replacing steam traps
I have an old two pipe system with warren webster steam traps. I have read that traps only last 3-5 years. Should these be changed? I have been here 13 years and have never changed them. Recently one radiator stopped working, I opened trap and found it stuck closed. I am wondering if others are stuck open, and how much energy does this waste. System is quiet and other 20 radiators work. Great expense to replace all the traps ($35/each).
If I do change them is the Barnes and Jones or Tunstall replacement design better?
  • Fred Harwood
    Fred Harwood Member Posts: 261
    traps
    Some will last and last. Most WW traps fail and block the condensate and air, which will show up as a cold rad and some loss of boiler water due to the radiator retention.
    The Barnes and Jones work well. Remember to remove the old seat. I keep a couple on hand, but I've never just changed traps for change sake.
    They close when steam arrives at the trap. In most balanced systems (radiator steam supply = condensing rate) the thermostat will cancel before any rad fills, unless you set back the thermostat or fire less than two to three times an hour.
