In-floor radiant heating
tdim
Member Posts: 4
Not sure if this question is for this site or not but any helpful insite would be greatly appreciated. I have a weil mclain hot water boiler model he4. For those that are familiar, the startup sequence on it involves the pilot relite control providing spark for the pilot. As of late I do not get spark at the pilot and going through the troubleshooting guide for the boiler( very useful and helpful) everything points to replacing the relit e control. I did that and once the system started up it worked. Unfortunetly, about 1 -2 minutes later it turned off again and now I get no spark again. Keep in mind this is the second time its been replaced(once last year and once now). It almost seems like something is blowing it. Unfortunetly, the troubleshooting guide does not state anything. I could replace it again, and may have the same problem. Not sure if someone has come across this out there.
i'd give the factory
technical service dept. a phone call..they can talk you thru the steps to take..they can be hard to get thru to, but if you get their voice mail, believe it or not they actually call back..
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.0
