Hoffman Model 508
mjbr24
Member Posts: 7
Can I use a Hoffman Model 508 Hygroscopic air vent in a cast iron baseboard steam unit? Most of what I read about it says it is for hot water heat. Also, if I can use it, do I leave it open a little (manual) or fully closed (auto). When I leave it closed, it appears that no air escapes and I do not get heat. It is a tight space and this is the only vent that I found that will fit.
- 86.8K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 104 Geothermal
- 69 Pipe Deterioration
- 952 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
