lochinvar 180,000 or dunkirk 175,000?
Constantin
Constantin Member Posts: 3,796
If the emitters allow it, go with a condensing boiler for the highest efficiency. Presumably, this is a gas-fired hot water system?
I'd strongly urge a heat loss calculation before anything is done. Frequently, boilers are waaaay oversized for todays loads in homes that have had weatherization and/or insulation retrofit. Our heating needs went down 4x per square foot...
  • kt
    kt Member Posts: 1
    Lockinvar or dunkirk
    I have two salesmen telling me that their boiler is the best. The Lockinvar is copper and the dunkirk is cast iron. I just want the best efficiency! Help!
  • Joe Brix
    Joe Brix Member Posts: 626
    If you want the best efficiency
    I wouldn't go with either. Look at Locknivar Knight (stainless steel) or the Dunkirk Quantum (aluminum).
