EZ Floor
Joseph T
Member Posts: 8
I am starting to look into a new product called RAZ-PANEL
from EZ-Floor. www.ezfloor.net It is a foam insulation that has raised offset bumps that hold the pipe instead of using staples. The product has a true r-value and looks like a promising method of install under a slab. Just wondering id anybody has used it ar any comments about how it looks, Thanks
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 951 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
