Reverse flow in mix valve?
Terry
Member Posts: 186
sounds like a missing check valve ?
Reverse flow
With a sparco 3/4 mix valve- can head pressure on the primary loop cause flow back yhru the mix valve, back out the cold side into the outerside to the boiler return, I know I can put in a pdv valve on the primary loop, but I'm trying to adjust the bypass ball valve to make up a slight pressure difference to still feed the two other zones on zone valves, with the szones closed it seems to push water back thru the mix valve, but w/ the zones open, it's fine,,, I have a larger systen to do w/ alot more 5 zones ( 3 w zone valves, 1 rad w/ circ & 1 baseboard w/ circ contro) that I plan to use a dpv on.0 -
i agree. *~/:)
give it a choise of return...0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
